Question: My fogs worked when I disassembled the car for paint...got them back together, now they don't work. The connectors seemed the same...to me, would getting them reversed prevent them from functioning properly? Perhaps I don't have the hot/ground wires connnected right?
TIA
The grounding points require some of the paint under the bolt head to be scraped off. Are you getting 12V to the fog lamps? Another possibility is the 10 amp circuit breakers for these things are pretty cheesy, and just plain wear out.
Concur with Midlife. Those circuit breakers age and are almost always the culprit. Jumper across it to verify.
