Is anyone running a 16x8 rim with 225/55-16 tires on the front of a 65 Mustang? If so what coil springs are in the car? Do you have the UCA lowered (Shelby Mod)?
Is your car at stock ride height or lowered ?
215/55/16 16x7 wheel 4.5 backspace 620 coils 4 leaf mideyes
225/50/16 16x7 wheels 4.5 BS 620 coils - half loop cut off and UCA drop. Same rear as above
225/55/16 should be ok in the back but might be tall in the front
I've had 16x8's with 225/50/16's on my '66 since about 1989. You will need an
aftermarket upper control arm to accomplish this feat. In general, they swing
in a more preferable arc and miss the fender opening when at ride height,
unlike the stock upper arm which swings CLOSER to the opening at ride
height and moving dynamically. You can cheat by using stupidly high ride
heights and/or different rim sizes but that is basically where it's at..... the
right way or the not quite right way.
The 65/66 is a unique deal because there isn't much fender leeway on that car.
Fenders on my GT are also un-flared fiberglass units, pretty unforgiving as far
as tire contact is concerned.
ex-Global West GM
1991-1995
fast65ford- I just noticed you were talking 55 series...... that would
be even a tighter fit on 65/66. Very tall tire.
I had them on my '68 at one time. Almost too much on that car,
even with the trick UCAs.
ex-Global West GM
1991-1995
Never would of guessed them being fiberglass
They were one of the first sets Maier ever made. and a royal PITA to
install. Had to make templates for all the emblems and letters.
I think I had 17 hours per side to fit them out of the box.
Maybe an additional 5-7 hours went into them prior to the paint booth
but I don't know for sure, I don't paint cars......
ex-Global West GM
1991-1995
