Greetings-
I noticed the center post on the water pump that goes through the pulley is hitting/rubbing the center of my electric fan mounted to the radiator. It has the slightest of opening when not in use but either engine movement or expansion of the aluminum radiator makes the post rub/rotate into the back of the new electric fan. Any options to shorten the center post on the water pump or way to avoid this bc I dont see any option to adjust the electric fan. Concerned over time this could wear down or break the electric fan. Any help is appreciated.
