·Guest
I found where Mustangs and Fords(August 2000) published alignment specs for 65-73 Mustangs. They are as follows:
Left
Caster 2 degrees postive
Camber 1/2 degree negative
Toe 1/32 out
Right
Caster 2 1/2 degrees positive
Toe 1/32 out
The thing that concerns me most is the toe out instead of toe in. Has anyone ever tried these
settings? If not, what are some good settings to use.
Thanks,
Mike
Left
Toe 1/32 out
Right
Toe 1/32 out
Thanks,
Mike
