I looked through several posts with similar issues, but nothing quite like I’m having.
The horn on my 65 has never worked correctly. I wired a temp fix several years ago (separate horn button on the column using the yellow/green and separate constant power) but recently swapped out the turn signal wiring and was hoping that would fix the issue. It did not. I know my wiring is correct in the harness, but when I press the horn the yellow wire post sparks and (obviously) the horn does not activate.
Clearly it’s a constant power issue but any thoughts on what might be causing this? I’m stumped.
