Hi all,
New guy here from Massachusetts.
Quick backstory on the 65. Picked it up for my dad last father's day. We drove it a decent amount, and ultimately parked it due to just about everything leaking and it overheated. June 1 2019, I pulled the drivetrain. Rebuilt the engine, resealed the transmission, and fixed the overheating issue with a 3 row aluminum radiator, 6 blade fan, clutch, shroud, and a 180* tstat. I'll save the rest of the details for another thread.
Here's the issue: Got the Mustang back together. Went to fire it up for the first time since the rebuild, and it would only start in neutral. The NSS switch was new. Looked through the service manual and saw a few threads on here that there is an adjustment. I went ahead and followed the procedure, and got the car to fire up in park (and of course neutral). Fast forward a couple days. I had a couple leaks I needed to address before making our maiden voyage. Went around the block a few times, then headed back home. Once home, I let the car idle in the driveway for a bit. While putting some tools away, I heard the car shut off. Odd. Went to see what happen, and couldn't find anything obvious. Went to start again, nothing. Moved the shifter down to 1, then back to park. Turned the key. It fired up. This happened a few other times since. I replaced the ignition switched. Started the car a handful of times with no issues. I thought I was all set. I dropped the Mustang off for an alignment Tuesday morning. Got the call that the car was all set to be picked up. The guy told me he had an issue starting it a couple times, and it died on him once pulled out of the garage. I told him I was aware of the issue. While trying to drive the car home, it shut off on me 5 times in the parking lot. While in gear. Would not start in park, only in neutral. My question is: could the NSS still need adjustment? Causing the car to quit while in gear? Is the ignition switch faulty? Or do I have a bigger issue. **Engine temperature doesn't seem to make a difference, as it shows the same symptoms whether the car is hot or cold. Electrical isn't my favorite, but there can't be much to these switches in my opinion.
Thanks in advance for the help!
