1 - 20 of 22 Posts
Thinking about taking out the 302 and putting in a more modern engine. That being said what is the most modern engine I can install without removing the shock towers? thanks a million.
How about a 2JZ?
Reactions: blueovalfan68
Well, the 5.0/302 was still used in production vehicles through 2001. Is that "modern" enough? If not for government pollution standards it'd probably STILL be made. LOL. From what I understand, the new 7.3 litre "Godzilla" pushrod engine will fit between the towers with a bit of "notching".
Are you running a 3G alternator, electric fan, EFI, and electric water pump? Does your current 302 have a roller cam? There are plenty of ways to modernize a windsor block. Obviously the modular 4.6 and 5.0 Coyote require removing or notching towers. I have seen cars with the 4 and 6 cylinder ecoboost engines into these cars, but that probably wouldn't fit your description. The 7.3 Godzilla is completely new territory.
Yeah, those 289/302 engines really suck.
764079
Of course, as stated, you could install fuel injection and electronic ignition pretty easily.
instead of looking for a "more modern" engine to install, how about updating what you have? installing aluminum heads for instance would make a big difference in power out put and efficiency. changing the old outdated cam design to a more modern one with better ramp rates, roller lifters, etc. also helps. add to that a modern intake and EFI system along with electronic ignition controls built in will also do wonders with driveability.
If you are talking about putting a Chevy engine in a Mustang, why not. Maybe replace the aprons with Camaro aprons, the fenders with Impala fenders, the roof with a Chevette roof, etc.
Better yet, I think a Studebaker engine would be the best.
Discussion Starter #14
I'm running a single wire alternator with electric fan and fitech EFI and a manual water pump. No roller cam just a stock 87' F150 block. I need to research more about the Godzilla. Thank you.
Discussion Starter #15
That crossed my mind many times and it is still on the drawing board. I am running an electronic ignition, fitech EFI, long tube headers. Thank you.
Discussion Starter #16
Actually I have looked at some LS1 swaps and I am open to anything.
Oddly enough, Studebaker sold a 289 engine for years.
764152
Get a new toy yoda or nissan or honda engine.
He's going to 4th ! Gear that is.
1 - 20 of 22 Posts
