has anyone tried rebuilding a 65 -66 steering gear box? ive got some play in mine and i was wondering if its all that difficult to accomplish.
Have not done it yet but Im gonna sooner or later in my resto . You might be able to adjust your unit with the adjust screw to remove the slop though . Check the manual or someone can give you the heads up on the adjustment . It's been 14 years since I last adjusted one :)
From all I've read and heard it isn't worth the effort as compared to replacing the whole gear box. That's what I did, see my article here if you like
http://www.inficad.com/~moneymanager/gearbox.htm
Doc the moneymanager
http://moneymanagment.info/onehorsepower.jpg
I rebuilt my gearbox a couple years ago. Its not too difficult, but the price of the replacement parts are high. It was worth the effort, and cheaper than a new one.
Joe
I found that most still have adjustment left, but it also needs the original grease replaced. If you look inside, it usually looks like grey plastic! Dig out as much as you can and stick your grease gun down each side and pump away. We then squirt silicone inside to help. We've only had to replace only 1 box since 1991. ::
