Changed from 1 speed to 2 speed wiper system and now trying to get the washer system working. On mounting the washer pump, does the smaller hose fitting point up or down when mounted. I’m assuming it points down since this is the feed to the nozzles and gravity may help but I’m not sure. Anyone know the correct mounting orientation for the 2 speed washer pump?
The washer motor mounts horizontally with the moto on top and hose nozzles parallel to the frame rail below
Sent from my SM-N960U using Tapatalk
2 speed washer pump has only 2 mounting screws and the nozzles are 1 on top and one on the bottom. 1 speed washer pump is the one with 3 mounting holes and nozzles side by side on the bottom. I need the orientation for the 2 speed pump.
