Two questions, Ordered 2 new brake hoses for the Shelby. Shop manual shows 1 gasget for each hose on the caliper end of the hose, correct? I thought the new hoses would have included a new gasget. Wrong. Now get to order 2 $.42 gasgets. Looks like the rear hose does not need gasgets, correct? Also, the mounting tab on the rear hose that mounts to the axle tube sure looks longer than the stock tab, although I didn't remove the original for an exact comparison. Anyone experiance this? Do the stock hard lines still line up? All parts from NPD...
Sounds right to me, 1 copper washer between the flexible hose and the caliper. The rear line should have an inverted flare on the "front" side, and probably the same on the end that screws into the distribution block.
Thanks guys. Probably my mistake about not ordering the 2 washers. I know better than to assume.
Washers were $.42 each * 2 = $.84 plus $6.50 shipping... NPD would not just put them in an envelope with a stamp.
