1 - 10 of 10 Posts
Was driving the car today and noticed that i had no power to the fuel gage, oil press gage, water temp gage, and no turn signals....also wired to the ACC side are the radio and tach, both not working. I've did some wire chasing and everything looks good....i'm thinking it may be the ignition switch has gone bad. From the looks of the schematic all theses acc's run through the ign switch. What do you think?
I would agree with you except for the turn signals. That throws me off a bit unless it is just coincidental that they don't work too.
Dumb question - you've checked the fuses?
Is it left/right and front/rear turn signals that don't work or just the indicators on the dash?
Do tour tail lights and parking lights work?
Fuses are good and grounds are good....tail lights, headlights, and brake lights are good. Everything worked for a brief moment when i was playing with it last night then it all went dead again
How about the ground wire that attaches behind the instrument housing to the frame? That's one that can come loose with "playing"
Get a simple volt meter or test light and follow the current until there is none.
Check your headlight switch. I'm not sure about the AC running through there, but everything else that you mentioned goes through the light switch. It might have a short or something like that and would give you a heck of a headache. That would be my suggestion to check. Good luck finding the problem either way.
Then I would look for a loose connection. The turn signals aren't fed from the ACC side but if it is only the turn signal indicators that don't work then it could be the ground to the instrument panel that would explain everything.
1 - 10 of 10 Posts
