I received in the mail today from SSnake oyl seatbelt attachments bolts for my 66 GT coupe. The front seat hardware is 4 large bolts, 4 large metal washers (dark brown in color) and some plastic black washers 4 thick (1/4 inch) and 8 thin (1/8/ inch). The rear hardware is 4 big bolts and 4 lockwashers. Can someone explain to me how the washers (plastic and metal) fit into this equation.
Also, how do the seatbelt retractors work?
Thanks ..........rich
The sequence for the front seat belt bolts is: metal washer goes behind the carpet. Then, there is a black nylon washer on both sides of the seatbelt chrome piece when the bolt goes through.
I assume you have the add on retractors. You have to wind up the retractor then attach it.
Thanks, does it matter which side of the seatbelt chrome piece gets the 1/4 inch black nylon washer or 1/8 inch black nylon washer?
