The 65 wiring diagram has the wiring from the oil pressure sensor to a the idiot light at the back of the instrument cluster. Making the swap, switch the oil pressure sensor to a correct one for gauges and can I simply cut the light off and connect the two leads to the gauge?......It sounds too simple to be to correct.
Discussion Starter · #2 ·
I am slowly learning to do searches prior to posts!! After this post I did a search on the swap and found a great link posted by JHarvey. So I think I can figure it out now. Thanks anyway!
Discussion Starter · #4 ·
Your how to will work just fine....less of course you want to drive up and personally do the job. All I could offer would be a cool fan and ice cold beer! Thanks for the tips!
Sanford
