I have a '66, 289 Auto, absolutely stock that I have had since 1 year old. Local "machine shop" screwed up the LEFT axle shaft when replacing the bearing and I need another one. What do I need to look for? What years will work and where should I begin to look? The shop damaged the surface where the seal runs so I assume I will have leak problems. How about metal spray or similar process to fix the damage? Thanks in advance for the advice.
65 Conv., 65 & 66 Coupes and the remains of
a 66' Coupe with 6 cyl. engine and V-8 3 spd.
It would be nice if I had a picture of the damage...
It is possible to turn the seal area as much as .015" undersize to correct scratches....as long as you use a neoprene seal with the coil spring loaded lip...
A nice closeup would likely tell me what I need to know...
Replacement axles can be found in 65-66 Mustangs, Comets, Falcons....probably some earlier Ford products as well with the same width...
Take a look at different rear end widths here
Pat
http://albums.photopoint.com/j/View?u=1570936&a=11937754&p=42910787.jpg
Hi, i would take a walk around the local junkyards and see if I could find another one then I would find another machine shop unless it is a friend in which case he should at least pay for the axle. John
Opal frost pearl metallic 67 coupe http://www.jps.net/binay/webdocs/febef75b01.JPG
also have a 95 opal frost pearl G/T BOSS edition convertible belongs to swmbo
