I picked up a set of the newer style, bolt-thru motor mounts for my 65 FB. I'm replacing the older stud type mm. They don't fit!!!. The old ones are attached to the body by three bolts. The new ones use only two bolts. The only way they can attach with the existing holes, is if I use the two innermost holes that are lined up one over the other. But when attached this way, they are turned down to far and don't line up at all with the insulator on the block. When I try to bolt the new mm using the other bolt hole that is more out toward the shock tower and the bottom hole of the two inner holes, the outer hole is about 1/2 in off from the whole in the bracket. I can't rotate it any farther because of interference of a protrubing tab on the bracket with the body. This may sound confusing to you, so please post any ? that may help for me to explain this better. I've checked all my catalogs, but can't find the right picture angle to point out the "tab" or part that is causing the interference.
65 FB "J" 302 lots of mods. 94 GT K&N only.
http://albums.photopoint.com/j/view?u=1590489&a=12113030&p=43871256&Sequence=7&res=high.jpg
