A while ago I bought a 66 mustang to rebuild. Ive had issues with grinding on startup even after replacing the starter. Upon removing the flywheel to redo the ring gear I realise I have a 136t ring gear. Apparently 132 and 157 are the only ring gears listed for this year.
I have a 3spd manual and a 9"clutch on the flywheel.
Do I just have the wrong size flywheel, bellhousing and whatnot, or is this just a rare case?
I found a ring gear that have matching teeth and dimensions, but its listed as a 1970s mustang ring gear, is that what I need and why?
