A few months ago I posted on here asking about installing a monte carlo bar in my 1966 mustang with a Blueprint 347 that came with an HEI distributor. Many of you strongly recommended that I swap out the HEI for something different. I took your advice, though probably went a little overboard.
I installed a MSD direct ignition system. Its a coil near plug system that utilizes MSD's dual synch distributor, LS3 coils and a DIS control box. The equipment is very high quality and the installation was very easy. The engine runs much stronger in the upper RPMs and I can install a monte carlo bar again! There is no vacuum or mechanical advance so all ignition tuning is done through a laptop, which has been fun to mess around with.
It was a fun project, though still on-going since I haven't finished the tune and I haven't seen another install like this before. On the plus side it also cleaned up the engine bay a bit.
Before:
After:
Before:
After:
