Well, as the title says, I have a 66 coupe, and the original ammeter was blown, so I soldered the connection back into place. Hooked it up again, and it blew out. Re-soldered, hooked up again, once again it blew...
I finally decided to order a new one, and low-and-behold, when it's hooked up, it releases alot of smoke, along with some popping... I immediately unplugged it to keep it from the same fate of my other gauge...
What in the world is going on here???
Thanks,
Dave
you have short somewhere in the wiring harness. Your new ampmeter is likely ruined. First of all buy a factory shop manual or at least a '66 wiring diagram. That should help you trace the wiring from the gauge. Do not plug in a new ampmeter until you have found the short circuit.
Z.
Hmm... I checked voltage across the two wires, it was 12.62, and the voltage at the battery was 12.63...
Fortunately, I don't think the gauge is blown, as it gives resistances varying from 200 ohms to 20 ohms...
Discussion Starter · #4 ·
Can anyone verify the data I posted above? Is that normal?
OMG. Somewhere, someone has altered the wiring as though it were a real ammeter. It's an indicator, wired in parallel with the charging circuit, not supposed to be in series.
