1 - 17 of 17 Posts
Any one have a template of the exact location to cut out hole in door to install pony courtesy lights ?
I made the attached over 40 years ago from dimensions I took on a 66 with Deluxe Interior that I found at a junkyard.
For what it's worth. One would think that in those 40 years, someone would have come up with something better.
Bob
Very nice Bob!
I will take some pictures tomorrow on my 65 factory stamped holes.
Bob
Bob,
are some additional dimensions you may want to add to your drawing.
Everything I have ever seen referring to this is generic and extremely vague.
Looks like you spent some time making that drawing. Sitting in junkyard or at home? 🤙🏼🤙🏼
Dan
Dan : As a young, 30 year old Civil Engineer 40 some years ago, who was also "into" cars, I was, and still am for that matter, into details. I made general location measurements at the junkyard, and also made a very accurate tracing/ template of the opening. Once home,I then determined the radii of the curves using a circle template.After gathering all of the dimensions, I decided to make an accurate drawing, to scale, and decided to make it a little more "professional" looking by taking the time to type (yes with an actual typewriter - remember those?) the text and dimensions. The additional information provided by Nos681 would be great to add to my drawing. As a matter of fact, I will redo it in total with the added information, which should prove a lot easier now by computer than it was by hand 40 some years ago. We should end up with a detailed drawing that should be far from vague, that those in the future can use with confidence. If while developing the new drawing, I find something that might leave a question, I'll get in touch with Nos681 for any additional measurements.
Bob
After you update your drawing, could you post it or email it me for my files?
I would appreciate it.
Thanks,
Dan
Absolutely. Although it might be a few days, but will do.
Bob
Bob, If you can give me the dimensions of width and height with the other radius that you already posted I can cut a pattern out of some stainless with a laser so that it could be traced positioned in the proper place and traced to be cut out..
Thanks,
Dan
Dan : Absolutely ; no problem. Currently modifying my drawing, adding some of your information, along with one of your pictures, to end up with a "step by step" approach to add ing the cutout, using a template. Hopefully this will be worth the wait.
Bob
I did some measuring of my own and cut it out of stainless.. It needs a little tweaking but it works...
743310
1 - 17 of 17 Posts
