Hi - I just bought a 66 GT Coupe. It has the factory 4 speed, with the finger pull reverse lockout. I think it is a T10 transmission. It seems like the shifter is really sloppy. Is there some kind of rebuild kit that I can buy that will have all the plastic bushings and stuff like that to restore the shifter?
Thanks!
Most of the mustang specialty places sell the kits for around 15-20 dollars.They will give you the new steel cups and springs, along with rubber grommets for the handle for where the bolts pass through-it is usually a combination of these being worn out and of one or both of the cups falling out that makes for the slop.I would check with Mustangs Unlimted, NPD,RestoreMustangs.com or CJ pony parts for best prices.Not sure if new bolts come with the kits, you may want to pick up a couple of these new special shoulder bolts, sometimes if bushings are real bad they get worn too.
1967 S code GT Deluxe Coupe 65B
1966 Convertible 76B 289 4 speed
1964 Fairlane 500 2DR HT-the new project
1986 Jeep Cherokee 4X4 the "beater"
http://albums.photopoint.com/j/View?u=1573428&a=11959254&p=43023698.jpg
This will cure some of the slop. But a really worn shifter will have the "Lower" shifter that is pinned to the shift shaft worn as well. It is press fit to the shaft. Repros are available if needed.
To find out...remove the shift handle and move the lower shifter that the shift handle bolts to. It should pivot around the pin but not have any perceptable play from an enlongated hole.
Scott
National Parts Depot
1965 Conv:Street driven concours
1966 Coupe: Daily driver and toy
I have seen the part you talk about broken, but hardly ever worn, but at over $50 for that tiny little U-ee thing, I have just taken a 3 speed shifter base and converted over, you can usually pick up an entire used 3 speed shifter for $10 to $20 dollars.
