Thanks for the previous replys and diagrams. Unfortunately, none of the diagrams or manuals for '65 or '66 show a single speed wiper switch WITH the pull to wash feature.
If anyone has this setup, I just need to know where the white washer power wire connects. One end plugs into the back of the wiper switch, the other has a male bullet connector. I can't figure out where it goes into the main wiring harness.
Thanks again for the assistance.
I don't think it does go through the main wiring. It is a separate wire feed through the firewall up to washer pump motor. Go up to to your pump motor and see if you have a wire there. Follow it back into dash and hook to your white one. Make sure you have +12V on that wire when wiper know is pulled... good luck! ::
I've got the same set-up, and IIRC, I have 12V to the washer pump, and pulling the switch grounds the circuit.
