1281 - 1299 of 1299 Posts
That 69 has a bad camber problem!
Mark
You can never have enough negative camber!
36 years framing houses and I've hunt down a finger or 2 to put in the cooler for the emergency room. Fortunately not mine! I won't recall my own ER visits. You will be fine Allen! My last year in the field I witnessed a 16P nail directly into the knee flush with the surface of the skin via a nail gun. No blood, lots of screaming.
Pretty close, except you have a lot more fan. “Seems” like you’d be fine emulating him if you can slow them big blades down a bit.
Discussion Starter #1,284
I need to start looking at pulley ratios. The fan has a 13" pulley which in my opinion will help greatly. I can just use a small pulley on the motor and it should slow it down considerably.
The thing I'm reading on that website is that you don't want to create a wind tunnel...
Allen
I think with pulley sizes you should have lots of options.
1968 coupe, 1968 vert, 1966 coupe
Will you just be doing drywall on the inside? Or some type of plastic paneling?
Painting it white I assume. I think some Vintage Burgundy accents would look nice, and be an homage to me and Patrick. Win/win.
Discussion Starter #1,292
Good looking stuff. Expensive though. I wouldn't mind having the back wall permanent and somehow have the side walls and front wall/doors removable so I wouldn't lose all that space when I'm not using the room for painting. That would be much lighter than drywall would be for such a purpose...
Allen
They also make strips that go between the two panels for a more finished look!
Discussion Starter #1,294 (Edited)
767275
Got the work bench top framed out...My question is what should I make the height of the opening for the air to draw through as illustrated in the next picture (the bench is 38" from the floor to the top)?
767276
Allen
EDIT: I meant to also ask, does anyone know of a good solution to make modular walls (like 4' x 8' sections) that I could put up when needing the booth then take down and store? I figure a 4' x 8' section with drywall is ~100lbs.
Discussion Starter #1,295
These panels look like they would do the job. Not sure of the cost.
Allen
I was thinking you were just building a temporary booth. That's why I couldn't figure out why you wanted to go through that much trouble of hiring a learned consultant like @Russtang. I'm seeing the big plan. You do nice work, when you do it. (y)
