1 - 12 of 12 Posts
In my glove compartment, 66 coupe, deluxe pony interior, where would the sticker go that tells the information about proper tire size and inflation information ? I did not take any pictures of the old glove compartment insert and I want to be absolutely correct on the new one!
Many thanks !
Johnny Knowles
They are generally found on the left side of the rear panel. Remember, these were install by humans and not robots so there is no exact location.
Thanks for your response..i take that to mean that the sticker goes on the back center wall of the glove compartment...left corner ??
From the MCA rulebook:
Tire Pressure Decal: 65 - may or may not have decal. 66 - in glove box on back left corner or on inside of glove box door. 65-66 - Red Line tires must have Red Line decal on glove box door. T5 may have MUSTANG deleted.
If I have the emerg flasher switch mounted on the left side won't it cover up the sticker?
Discussion Starter · #6 ·
Thanks Charles, I had seen the stickers in both spots and was not sure which was right, so I guess either spot is corect.
On a different note, what about the sticker on the dryer on the condenser ??? There was a Ford product sticker on mine, and I am sure that it went on the end by the hose, but I do not recall if the sticker was horizontal or vertical ?? How about this question ???? And I bet you will tell me to always take pictures, which I hope I never have to do again ! When this one is over, I am POOPED!
Discussion Starter · #9 ·
Hey Charles,
What about the question about the FORD sticker on the dryer with the condenser ? Is it horizontal or vertical ?
My old '65 had it mounted on the left...but all my '66's (I had 5 previously)had it mounted directly in the center.. probably because like someone said... In '66 ...All cars came with Emergency Flashers... And if you mounted it all the way over to the left...You really can't see it (BEING THE DECAL) because the emergency flasher and its wiring are directly in the way...so on a '66, The center makes more sense...common logic... but I would have to agree on a '65.. They are probably found more on the left...those cars without emergency flashers that is...At least here on the east coast...
Tony Kovar
1966 Sprint 200 Convertible
Discussion Starter · #12 ·
Thanks very much Charles ! I am now getting down to the "nitty-gritty" on the car, and I am too far along and I have entirely too much $$$$$$$ invested to mess it up now !
1 - 12 of 12 Posts
