Please reply direct to; [email protected] with your zip code for a shipping quote and any questions...
Complete 68 (w/289-302), working power steering set up. Gear box, pump, hoses, brackets, centerlink, tie rods, frame brackets, piston, control head and all nuts & bolts, $250.00
Red 68 center console, crack free exterior and very complete, less shifter and radio knobs. Even the has original mounting screws. Bar behind radio missing a 3 inch section but not visible. $325.00
Trunk lid torsen rods, $15.00
Trunk Hinges, coupe; $25.00 set
Tag light; $10.00
Trunk J-hook bracket; $15.00
Rear panel, center bracket; $15.00
Tank filler neck $8.00
Standard cluster; $15.00 (w/o bezel)
Rear wiring harness, nice; $40.00
Front headlight harness; $50.00
289 heads, early 65, stock/complete; $85.00
289 exhaust manifolds; $45.00 set
289 4V intake; $90.00
C-4 trans and converter. Worked fine when pulled; $125.00
Auto shifter, $40.00
Shifter bezels; $20.00
C4 shifter rod; $25.00
Bell cranks; $20.00
Shifter area patch (sectioned 4+ inches around hole); $35.00
Trans cross members; $25.00
Emergency brake handle assembly(inside); $25.00
Rust free shock towers; $60.00 ea.
Tower braces; $15.00 ea.
Spring covers; $25.00 ea.
Lower engine cross member; $25.00, w/bolts; $30.00
Strut rods; $15.00 ea.
Strut rod brackets; $35.00 ea.
68-V8 ft. spindle/drum assy.; $35.00 ea.
6 cyl. spindle/drum assy.; $20.00 ea.
V8 frame motor mounts; $40.00 set
Ft. core support w/lower crossmember; $75.00
V8 Coil springs $15.00
V8 equalizer bar $15.00
6 cyl. motor mounts; $25.00 set
250 6 cyl., rebuilt w/low low miles $550.00
Drive shafts, 6 cyl. $25.00 / V8 $45.00
Fresh air box, plastic vent type; $25.00
Heater box; $55.00
Heater controls (nice chrome) $40.00
68 Seat belt set, black, very nice condition, standard, complete w/bolts-washers, $125.00
Complete A/C system, everything needed to do a changeover... Inquire???
Window regulators; $20.00 ea.
Door latches; $20.00
Coupe door glass; $20.00. tinted $60.00
Tinted quarter glass $25.00
Front glass, tinted/nice $100.00 (I belive it's a Carlite)
Coupe rear glass; $30.00 , Tinted $60.00
67 Front pass. seat, complete (blue/nice);$80.00
Seat tracks; $20.00 set
Coupe rear back seat top, black/nice $25.00
Cowl panel top $225.00
Coupe headliner bows; $30.00
67 Grill, horse, center and bars (good driver cond.); $55.00
Hood latch support $25.00
Lower ft grill filler panel(repro) w/3 orig. brackets; $40.00
Front window chrome, 5 piece set, no dents/scratches $75.00
67-8 Flat hood, no rust, $100.00 (MD pick up only)
2 Turn siginal inserts. w/lights,grills and wiring harness/clips $90.00
Left "A" pillar; $40.00 Right; $40.00
Behind door, striker post; $40.00ea.
5 lug 14x5 steel wheels; $20.00 ea.
80,000 ORIGINAL mile, 302-4V "J" code enging/trans. In car. Can hear run and drive. Never apart, carb to oil pan (less A/C pulleys, brackets, P/S pump and fan)...$1,400 for both
68 Cougar rear wiring harness, control box and tail lights in very good condition $225.00
Photos available
All parts + shipping from 20601.
Please reply direct to [email protected] with your zip code for a shipping quote and any questions...
Tag light; $10.00
Bell cranks; $20.00
Heater box; $55.00
Photos available
