1 - 2 of 2 Posts
How do you tell a manual non-power brake pedal from a power brake manual pedal? Is there a part# somewhere on the pedal and if so what it is it? Or does the power brake pedal just used a different push rod for the master cylinder?
Thanks,
Power brake pedals are significantly longer. Power brake pedal = 17" from bottom to top. Manual = 14" bottom to top. Also the spacing between the pivot point and the actuator rod attach point is different: Manual ~1 inch (little wider than your index finger), Power ~4 inches. If you need a pick of 67 pedals I have two in my shop right now.
1 - 2 of 2 Posts
