Actually, it is broke, and you should fix it. There's a shuttle pin inside the distribution block, and most likely it got off-center during brake repair or brake bleeding. I'd recenter it, and repair the wiring. Then if you should develop a leak in your brake system, the light will warn you.It's not broke so I'm not fixing it... This is just pure curiosity...
I agree on fixing this. It is a fail safe, it lets you know you have lost your brakes.Actually, it is broke, and you should fix it. There's a shuttle pin inside the distribution block, and most likely it got off-center during brake repair or brake bleeding. I'd recenter it, and repair the wiring. Then if you should develop a leak in your brake system, the light will warn you.It's not broke so I'm not fixing it... This is just pure curiosity...
There's even a special tool to hold the shuttle in place during brake work.
It is on the master cylinderWould it be possible for someone to posts a few pics of the switch and area you are discussing. I would be interested in seeing what your talking about.
Thanks.
For '67 & '68, stock setup the "switch" which monitors brake failure is NOT mounted on the master cylinder, but a single pin switch for 67 & dual pin switch for 68 is screwed onto center of the brake distribution block. (Not to be confused with the proportioning valve used only for disc brake cars).It is on the master cylinder
This pic of my 67 with factory disc brakes, I used a '68 proportioning valve but 67 switch because had to match wire harness. Also the 68 prop valve, has end cap that comes off to push centering shuttle if stuck.
Thanx for posting this! I had no idea this tool existed! Found one in the NPD catalog https://www.npdlink.com/product/mus...ms=shuttle%2Bcentered&top_parent=200001&year=Actually, it is broke, and you should fix it. There's a shuttle pin inside the distribution block, and most likely it got off-center during brake repair or brake bleeding. I'd recenter it, and repair the wiring. Then if you should develop a leak in your brake system, the light will warn you.
If not located near the driver's side rear shock absorber, and near the vent hose for the rear axle, you might see evidence of it being replaced with a short piece of tubing. Anyway it should definitely be there.Thanks for the info... I've not looked up the build date info on mine but considering what I learned just a few weeks back about my steering column I'm guessing it's a earlier '67 because it doesn't have the rag joint style steering box/column. I'll take a peek under the rear and see if there's one in there somewhere. If not I'll just follow the lines up to the front and see if it has anything in line anywhere. Gives me a starting point.
I thought I would add that the brake switch that mounts on the brake pedal comes in several different versions, all appearing and installing the same. The difference in switches is the tension of the spring that is inside the switch housing. For example, power brakes take less pedal pressure so the spring is lighter tension as compared to manual brakes. This is important becasue if you install the incorrect switch, your brake lights may not be coming on timely which is dangerous. Springs are colored according to tension, but I don't recall what color is which tension. Just be sure to have someone check your rear brake lights as you apply pedal pressure. The lights should come on with little pedal travel or pressure.Oh... Wouldn't have guessed that! Thanks for the heads up... Definitely didn't realize that.
On a side note, interesting that ford never really changed that switch cause i had a mid 90's explorer that had that exact same switch on the pedal. I guess like I said in the initial post, not broke, don't fix it? LOL
Yes, this is the 67-69 proportioning valve. Mounted a bit lower on late 67, and by the rear axle hose on early 67. And no, it is not adjustable, but it is rebuildable.I've got a factory disc brake car and I'm 99% sure I don't have a proportioning valve in my system. I'll have to double check but functionally, the rear definitely locks up too fast compared to the front. Is the cylinder just right'ish/below the distribution the proportioning valve? Is it adjustable somehow?
Mine is a dual pin (2 wire)...
