The Car
- 67 coupe, 289-2V, C4, 2.79 open
- Red std interior w/console
- Currently red, factory Whimbeldon white w/ red pin stripes
- Purchased Oct 2019
Existing Condition
- Engine runs but needs a rebuild. Is not the original engine, 66 build date stamped on the block (car is a late 67).
- Interior is in pretty decent condition. Console has some damage.
- Sheet metal work needed includes floor pans, torque box, floor supports, partial front and rear frame rails, front apron patches, inner/outer rocker patches, trunk drop offs, quarters and outer wheel wells. Quarters were replaced at some point but need another replacement.
The Plan
- Return the car to its original appearance w/ red pin stripes
- 351W swap, mild build, stock appearance. I will likely rebuild the 289 at some point and may return it to this car.
- Interior will get new paint, carpet, door panels and dash pad.
- Car will be completed in two phases. Phase 1 goal is to get it back on the road for summer 2020 by completing major mechanical and sheet metal work. Phase 2 will be completing the body work/paint and interior.
- I was initially going to restore this over a much longer period of time but a friend offered up his heated garage so I towed it over and got right to work.
I started this build thread a bit late but I’ll post all progress starting from the beginning of the project.
