1 - 2 of 2 Posts
I need help..The dash lights were working until...anyways I have replaced the headlight switch and the fuse in the fuse box is ok. Any other suggestions. Thanks Vance
Obviously the wiring connector pin is dirty or pushed out or the switch is bad. It worked before you replaced the switch, therefore it has something to do with the switch.
1 - 2 of 2 Posts
