Should the casting code on a 67 289 be: C7AE-6015-C ?
Thanks.
Off the top of my head, I believe they are C5 as the same block castings where still being used without change from 1965.
Actually, I decided to double check. My original 289 from my '67 has the casting number C5AE-6015F. If you are wanting to know if it is original for your '67, it might be better to check the casting date which appears beside the casting number. Mine is 7D7 (April 7, 1967).
