Factory AC car - I installed from a donor car. nothing every worked. just looked good having a factory system installed!
I'm fooling with the heating system in the car. I just got the blower motor to work with all three speeds.
Looking at the heater control valve -
1. WITHOUT vacuum applied - does water flow to the heater core?
or
2 WITH vacuum applied - does water flow to the heater core?
I figured I would continue on this thread. I am in the process of cleaning my valve up and moving it to a new mounting bracket. The bottom of the valve that sits on the bracket is open...the repops are closed. It looks like the valve body has a recess around the opening. Is there supposed to be a washer/gasket between the valve and the bracket? If so, what was it made of?
