67 Hood Question
686 7
OK guys. The hood on my 67 is the turn signal one but it doesn't have the holes for the Ford letters at the front edge. All other 67 hoods that I have seen have the Ford letters at the front edge. My hood is not a repro but it is not the hood originally on the car. Where have my Ford holes gone?
Tim Russell
Sale, Victoria, Australia
67 Convertible
The other possibility is that it is a Ford over the counter replacement hood, and they did not have the holes either.
65 Hi-Po F/B
67 GTA F/B (small block)
MCA 27479
I have the same problem on my '67 convertible - I think mine was a new replacement hood, because the double layer metal has holes cut out on the back leaving a place to get to the barrel nuts so you can mount the letters.
Beri Fraley
Strong, Proud, and Ugly.
I bought a hood off a 67 from a junk yard. I do not know if it was the original hood. It did not have the holes either. I used the old hood to make a template and drilled holes in my new hood.
http://albums.photopoint.com/j/View?u=1575962&a=11982331&p=43165927.jpg
67 Sprots Sprint, Convert. Original C code, now 293 ci with Holley 450 and 295,000 miles
my '68 coupe has them. in the old forum Laurie S had a summary of '67 '68 hoods with lights turn sig etc - you might try a search. also '68 Californis Specials did not have letters i believe
