1 - 2 of 2 Posts
I just received a master cylinder rebuild kit from NPD. The kit came with two check valves that are the same diameter. Mine MC has two different dia. check valves & brake line fitting. I called and checked the part number and it is correct for a 67. Could I have a late 66 master cyl? The book does show a different number for 66 master cyl. Thanks.
Concensis is that rebuilt master cylinders don't last and aren't worth the trouble. Brand new is the way to go.
1 - 2 of 2 Posts
