Hello everyone, hope everyone is safe. After the engine warms up the blue smoke is gone!
I try to drive it once a week. Do you think that I need new piston rings? Remember the blue smoke is only at starting.
thank you
My bet is on valve stem seals. Oil leaks slowly into the cylinders when it's not running, the oil collects in the cylinders. Once up and running it burns it off quickly.
As Dave said, valve stem seals. Probably the old umbrella seals that break apart and end up in the oil pan.
Smoke on start up = valve seals
Smoke all the time = rings
Sent from my SM-N960U using Tapatalk
Valve seals can be changed without pulling the heads. But you need a different type of valve spring compressor and the fitting that goes in the head. Also you need a air compressor.
If it’s the stock, 50 year old motor, just rebuild the entire short block when the time comes. For now just drive it.
You can do it without an air compressor, pull the spark plug, shove rope in thru the plug hole, rotate crankshaft by hand to push rope in cylinder up against valves and change the seals. Old trick I remember reading about.
