I have a 67 Mustang power front disc rear drum. I have a proportioning valve installed in the rear brake line back in the line before it reaches the rear axle and splits to each wheel. Everyone is telling me they only put these valves up front near the distribution block and they only used the cylinder type valves, but the pictures show where mine is and what it looks like.
1) Did they use proportioning valves for disc/drum applications or do you think my rear axle is not factory?
2) Since the cylinder style valves are more readily available, could I just swap one of those in for the one I have assuming the fitting sizes are the same?
I can't be the only mustang owner with this valve so hoping for some guidance.
Thanks, Greg
Thanks, Greg
