1 - 17 of 17 Posts
Going to be helping my father in-law restore his dad's 67 Mustang coupe, 289 automatic. I'm suggesting to him that he replaces all of the wiring harnesses with new. Anyone have any suggestions on good OEM complete wiring harnesses to buy?
Send the originals to "Midlife" for restoration. You'll have to use the search function to find Midlife. He is a member of most old Mustang websites.
I don’t see the need to replace it, maybe clean it up. My car was in about as bad of shape as you can get and my wiring harness works fine.
^+1 He was hit by the hurricanes a while back and was hoping to be back at it around now...may be a bit backlogged.
He does a great job at a reasonable price. He really doesn’t do “concours” stuff, but fixes original to be functional and safe. I suspect it would be much cheaper than an aftermarket and will be specific to your application.
If you don't choose Randy, check out Alloy Metal Products harnesses.
Been emailing Randy,seems very helpful! I will check out Alloy Metal products too. Thanks!
This is pertinent to a coupe project I will be bringing home over the Winter. The seller says the harness is intact, but rough. These options are excellent. I am also looking at the Painless pre-cut and terminated kit. While it is exspensive, the time it can save may be worth it.
I had a S-code fastback burn in the '80s, insurance chalked it up to old/dried/cracked wiring, and that was 30+ years ago!
I'd not trust (now 50+ year old wires) an original harness in a restored car, yeah I know I may be paranoid, but when these cars were made they were expected to live 5-10 years.
I'll never tell anyone it was painless (hell I'm still working on my speedometer) but the universal kit from Painless was of a much higher quality that 1960's OEM, and costs far less than a new OEM style harness, plus I've converted to a new fuse box with the blade style fuses.
Just something to consider.
Generally in the past Midlife (Randy) has recommended new harnesses under the hood (main headlight, gauge feed, and alternator) as the underhood environment really cooks the insulation over time. From the firewall back, (main underdash, taillight, and ancillary) refurbishing is a reasonably priced alternative.
If you decide to go for new reproduction harnesses, they are factory correct, color coded, and plug an play. I've redone two '67 fastbacks and the ease of plug and play is remarkable.
Depending on your wiring skills and the time you have available to rewire the car, the Painless terminate-it-yourself option can save you some money at the eexpense of time. Value your time and make your decision.
Discussion Starter #11
Great discussion! byteme, you mentioned if I go for "new reproduction harnesses, they are factory correct, color coded, and plug and play", do you recommend a manufacture? I like the plug and play feature over terminate-it-yourself.
That was about 14 or so years ago and I am not 100%, but IIRC they were branded by Scott Drake. I bought them from Shaun (Street or Track). Perhaps he remembers??
Discussion Starter #15
How about CJ Pony? Anyone have any experience using their wiring harnesses? They advertise OEM style reproduction with correct plugs, connectors and colors.
The problem with CJ Pony is they're pretty much a drop ship engine these days. Thus, if you order the wiring harness from CJ Pony, you won't know when it will hit your porch and you won't get any customer support if you need it. If these issues don't bother you, and you simply like the CJ Pony price, go for it. I like ordering from NPD because almost everything they sell is in stock on their shelves. Furthermore, if I have questions, I can call or email and they will help me out.
FWIW, I had the under dash harness in my 1970 Mach 1 restored by Randy at Midlife. He did a great job! It's better than new. For all the wiring under the hood, I ordered new harnesses from NPD. Everything plugged right in and the harnesses are good quality. Be very careful ordering. There were a lot of variations for wiring harnesses. Again, NPD can help you there. Call them, tell them what car you have and they will help you to select the exact wiring harnesses you need.
Discussion Starter #17
Thank you Klutch!! I will definitely consider NPD for the underhood harnesses! I will have Randy do the under dash when he gets back up and running after February 1.
1 - 17 of 17 Posts
