I just drove my 67 fastback for the first time this week! It took me 3 years to complete.....The engine fired up pretty easy but....I have noticed two things. 1. The power steering pump was howling a little bit so I unhooked it so I could break in the cam without worrying about the pump. I have been driving around without the pump and it is pretty easy to steer. Problem is that there is excessive play in the steering and it has a completely rebuilt power steering box. Can anything else contribute to excessive play? I just had the car aligned.
2. I have a terrible "creaking" sound in the front end. Brand new suspension with rubber bushings. It is not like the sound of an upper control arm bushing but almost like a "quick binding" sound. Any ideas on that one? Thanks, Jim
Without the pump hooked up you WILL have a lot of play in the steering. The ball stud actuates the hydraulics, and without them hydraulics working, it will move around in the sleeve quite a bit before moving the linkage manually.
Yeah... I replaced just about everything on my '67 - Centerlink, tie rods, power-valve (steering box has no play) but even with the PS running, that ball-stud still has to move a bit to actuate the fluid. I was pretty disappointed with all the money spent with little improvement. I believe the '67 factory PS is about the most complex and "crappy" steering design out there. If I would have known, I'd have gone with a rack&pinion unit... probably will in the future some time... Good luck!
Understand that the ball stud has to move for the valve to do it job. It is a very good reliable system. You need to simply understand it. hope this helps.
Rodes Restoration in Galion OH can do something to the valve assy that helps (though doesn't cure) this problem. I know not what it is, but it sure helped mine.
