If it's the late '67 style box with the rag joint then you are not going to be able to use it. The collapsible setup has a 1 1/8" sector shaft which is where the pitman arm attaches, the earlier '67 box with the long shaft and no rag joint has a 1" sector shaft which is the same as a 65/66 setup.
I don't think you can use the pitman arm for either '67 setup in a 65/6 steering assembly because it has a different mounting system to the centerlink... and the idler arms are different too. Perhaps you can swap the whole late '67 setup in, this I do not know.
