I don't know where to start. I have had this project running for awhile now. I tend to just stockpile parts. About half of the items below are installed or have been prepped to dropped in quickly but have not been install to ease installation of other components.
I buy a lot of new things because I don't have any of the components or I just want to upgrade somethings. I am always shopping for a deal.
I got a great deal on a completely tore down, blasted, primed and lizard skinned shell with a couple of nice new parts. I got a freshly machined 302 block for a couple hundred and I can get the power I want out of it. I foolishly keep an excel file of my build cost. I does nothing for keeping me inside my budget. This is going to be my weekend driver for a long time.
I am working out of my finished 2 car garage. I keep the sparks to a minimum. I am doing as much work as I can do. I lack paint and body skill and tools though.
Desired mods
EFI (gas or e85)
disc brakes
adjustable coilovers
power seats (maybe heated)
power windows
power locks
power button start
double din radio with good audio setup
parking brake relocation
might relocate ac controls if I can get my friend to scan ac controls and give me a CAD file
digital gauges
move that damn wiper switch from gauge cluster
Add cruise control and wiper to steering column
outsourced work list needs
body work (flares)
paint
maybe 3d cnc
The engine (I hope to have 400+rwhp)
F1SE OEM Block
347 stroker ~11:1 CR
Scat Crank
Scat Rod
Wiseco custom forged Flat top -6cc
Morel hyd lifters
Custom FTI cam over .600 lift 224/230 dur 111 sep
Afr 185 58cc heads with FTI springs
Scorpion 1.6 roller rocker arms
Rollmaster cam and crank gears
fel-pro 1011-1 (if I blow them, I'll buy some cometic mls)
Holley dist
Melling standard volume/pressure oil pump
Melling pick up
Stock rear sump pan
I have not decided on an intake yet.
Still trying to convince myself not to buy a Hi-ram intake because I'll need a new hood, or to modify the stock one.
Tanks Inc 22 gallon tank with FiTech 340 lph pump and sender (awaiting shipping)
The trans
New MDL T5 kit (new to me and 0 miles been sitting since 2017 or earlier)
I might upgrade some internals in the future and I will redo all the seal and look it over before running it.
The front end
MII setup for jw rod. I wasn't sure about it at first but I have tried to hate it but I cant. It came with the car.
Viking double adjust coilovers. (ok I only like the coilovers)
power unisteer rack
Disc brakes
The rear end
8.8 3.73 gears disc brakes
I have two one out of an explorer already chopped and installed
The other is out of an 04 GT I think its 1.5" wider which I might use if I get fender flares
The interior
TMI sport R black with white stitching everything basically
2018 Mustang seats
stock rear seats
TMI console
Nu-relic front and rear electric windows
Electric trunk release (on backorder)
AAW classic update harness
digital guard dawg push button start/ remote start lock controls
Autoworks power door lock kit
Still need
AC kit
engine acc
ECU
ididit steering column
Intake
gauge cluster (maybe dakota)
more sound deadening/insulation
Paint
Glass
Driveshaft
Fuel line
power steering lines
serpentine setup
Brake Lines
Time and motivation
Pics will be slowly added to this.
