I have a 6cyl 200. The air breather looks like it needs a snorkel attached to it..and I am told it came with one. I understand that it also came with a heat riser that was probably attached to an exhaust shroud...does any body have a picture or spare parts to complete this ? If you have a six cyl...how is yours set up?
Discussion Starter · #2 ·
Yes, a heat riser flange bolts to the exhaust pipe below the air cleaner. Pre-heater aluminum hose is supposed to attach to a flange on the exhast pipe and run up to the bottom of the air cleaner. I had that flange at one time...hmmm Didn't have any performance value so out it came /forums/images/icons/wink.gif
[color:blue]'68 Coupe
250/C4, 221 Argentine Head
Breakaway Converter, 9", 3.50's/T-lock</font color=blue>
Hi, mine is a sport sprint and doesn't have any place on it for a snorkle it is just a round air cleaner. John
Opal frost pearl metallic 67 coupe http://www.jps.net/binay/webdocs/febef75b01.JPG
also have a 95 opal frost pearl G/T BOSS edition convertible belongs to swmbo
Discussion Starter · #4 ·
They changed in 1968...
Discussion Starter · #5 ·
I think this is the picture you are looking for
http://www.homestead.com/InlineFever/files/66_200_6.jpg
John's right though........They have no performance value /forums/images/icons/wink.gif
Later,
Doug
[color:blue]66 Mustang Coupe 206ci</font color=blue>
[color:red]Six Packer Performance Freak</font color=red>
11.1 Compression/ 6,000 RPM/Clifford Cam & Valve Train
http://inlinefever.homestead.com/files/sig_pic.jpg
My 67 I6/200 just has a simple round air filter and none of the stuff connected to it as shown on your picture. Was that correct for 67? So many things on my car are out of spec that I never know. Where did that picture come from? I'd sure like to have one like that for my 67!
67 coupe, I6/200, and a C4
http://home.att.net/~wr.moore/LeftRear1.jpg
Randy (Learning as I go)
Discussion Starter · #7 ·
Randy, I scanned it out of a Ford motor manuel a while back and put the pic up on my website.
Supposedly that is the setup for 67-68. The 65-66 were supposed to have the air cleaner with no junk attatched.
I will double check my motor manuel and get back with you at lunch!
I checked and the manuels I have show this setup as a 67-68.
Later,
Doug
http://inlinefever.homestead.com/files/sig_pic.jpg<P ID="edit"><FONT SIZE=-1>Edited by Mustang_Geezer on 03/28/01 11:08 AM (server time).</FONT></P>
Discussion Starter · #8 ·
I have one, it's called a 'closed system' I believe. check out the 1968 shop manual for info on it. the oil cap had a male extrusion and a hose attatches from the oil cap to the air filter ...
1968 Coupe, 6cyl Std, Bench Seat. Driven through 10 years of College.
