1 - 10 of 10 Posts
(actually Slim Jr now)
Just read a similar question on 65/66. My 68 has factory Select-Air.
I replaced the front floor on both sides. Failed to note the location
of the hole for the drain hose. Is there a template or dimensions
availible for the location of the drain hole? I realize my car is not concours
but I would like to have this in the correct location.
Administrator
I can get you a picture tonight, if no one posts one before.
That would be fantastic! It was stupid of me not to record dimensions...make a sketch!
Tom,
PM me your address and I will mail you a paper template I just made off the son's 68 factory AC car.
Discussion Starter · #5 ·
Thanks Ted, I just PM'd you.
Administrator
Here's the picture, as promised:
http://www.tucsonpony.com/acdrain.jpg
Discussion Starter · #7 ·
Thanks Laurie. Problem is the hvac box is not in my car. I have no point of reference
to the pic you sent. I appreciate the pic but I need to cut the hole in the floor before
I reinstall the hvac box.
Administrator
Okay, that makes it harder. I don't have one of the coupe with the carpet out, but I might have one of Trouble. We added a/c to the car and used the measurement from my coupe to do it. I'll check my files.
Excerpt from the assembly manual: (page E7-8655-6) "use existing dimples and drill 1.00 dia. hole"
Discussion Starter · #10 ·
Problem is the car had fsctory air. I replaced the original floor. The dimple went
out with the rusted out passenger side floor!
1 - 10 of 10 Posts
