Just got new lights, housing, and wiring. Still does not work. Bulbs are new. Is there some kind of switch on the the tranny that i should be looking at or something with the brakes?
thanks all
You didn't say what kind of tranny you have (if you add some info
about your setup to your profile, it would help us help you).
Manual? The switch is on the shifter beneath the boot.
Automatic? The switch is in the tranny.
There should be a neutral safety swith located on the trans or in depending on whether you have a c4, c6 or fmx. the Fmx is located at the shifter. The c4 and some c6s are located on the side of the transmission behind the kick down lever. It will be a half round disk with one or two wires running from it.
