my dash pad was so decrepid it was hard to recognize. but i know with the 69/70 pads, there is some metal framing the pad is glued to.
the 68 pad i was only able to get the foam and vinyl off. do they have the metal framing too?
as of right now my dash has metal shaped the same as the dash with the grates for the speaker and two overhangs for the guages and glove box.....i cant get that off, but im not sure if its an actual part of the dash or not.
TIA
The dash is all vinyl and held in place by the cluster, center and pass trim panels. The dash is also held in at each end with a bracket formed in the dash pad. Sounds like your good to go.
Phil
ok thanks just wanted to make sure i wasnt missing something.
