I know this has probably been discussed before but I missed it. When I change my 68 drum brakes for disc brakes, do I need to find a disc brake pedal support? I see advertised all the components for the conversion to include the power brake pedal, but never the support. I know they do not make the support anymore so that is why it is not in catalogs but do I need to start checking junk yards and the e-place? Thanks
Doug
Only if you are also adding the power booster to the system. If you go with manual disks, no change is needed.
Even when switching from manual to power, it's only the brake pedal and not the support, right?
Not sure about that. I just tried the manual disks and figured if they were not powerful enough, I would add the booster and find a new pedal. But the manual disks work pretty well, and with the cam in my car, I wouldn't get much power boost anyway.
The reason for the PEDAL difference, is that the rod/pin on the manual and power (talking about brakes, aka having or not having a booster) is located differently on the pedal. This effects the "ratio" , aka, how much force is needed to push down on the pedal to get everything to work.
I *think* that since that brakes with the booster is in essence "easier", thus the pedal ratio is made a little bit harder. Since the non booster brakes are 'harder' (no booster helping), the pedal ratio is made "easier".
You can actually change the pedal ratio yourself by welding in a new pin. However, the exact location, I don't know.
I think the power pedal is actually LONGER in total length, which also affects things. (torque = force X radius). So the long pedal gives you more "radius", thus you get more torque.
For your 68, check out the ultrastang.com website. They added a late model booster. I *think* they changed the pin location also.
I hope that helps.
I have a 68, that I went to disc brakes. I stayed manual (no booster) brakes. They are a little hard to push sometimes, but I live with it. They work fine.
If I find a late model booster some day I might change it out. But its not a priority.
