I went to test a 68 fog light bulb by taking a couple of wires and connecting them to a battery and it suddenly started to smoke inside the light. Should I have not gone directly to the battery? Is there some sort of resister in a normal setup? Thanks
1967 Mustang GT fastback
Naw - just burned the light out IMHO- it's kapootski. The circuit does goes through a circuit breaker of about 10 or 15 amps, but still 12 volts. Just like testing a horn or wipers - connect them to + and - , then see if it works.
The smoke you saw was the tungsten filament frying due to heat buildup - resistance- in the tungsten filament itself. Resistance was caused by a thinning or crack in the filament. The thinning made it hard to carry the current from the battery, so it heated up and burned out at the thinning/crack point.
New bulb time.
Also make sure it was not a 6 volt farm tractor bulb. A friend gave me some old acc. lights with the rubber housing that came from a tractor, I tested them out the same way and the did the same thing. Took the bulbs out and on the back it said 6V
Electric lamps also do what he's describing when there no longer is a vacuum or inert gas inside
the bulb. End result is still "get a new bulb."
