· Premium Member
If someone has a moment ..could they give me a measurement from the quarter extension (where it meets the quarter panel) to the rear reflector. I want to mount the reflectors and since we put on new quarters .....I don't have any holes to go by ...thanks!
· Registered
My reflectors are off, so here are the measurements to the holes for the reflector. As you requested, from the joint where the quarter meets the extension - the rear hole is 2 5/16" to center, the front hole is 7 7/8" to center. Holes are 1/4" diameter.
I took no vertical measurement. Hope this helps.
· Registered
on my '68 coupe it is 1 in. from ext to point of reflector and the top of the reflector is 14.5 in. from trunk deck gooing across top of qtr down to top of reflector with flexible ruler. PM me if need more.
