·Guest
I finished an instrument cluster swap. Everything is working properly with the exception of the clock.
The circuit must be simple - one wire plugs-in to the back of the clock, it has to be hot all the time which means it's got to be connected to the lighting circuit somehow.
I'm reading through the wiring diagrams, but having trouble tracing the wire back from the clock.
Knowing that the clock itself is good, is there anywhere that I can check for voltage without removing the cluster again?
Thanks,
Bruce
Thanks,
Bruce
