·I have a '65 six cyl convertible and plan to put a 302 in it. If I use a '68 V8 rear end, which I know is longer than the '65, can I use standard wheels? I have front brakes from a Granada to install.
I know you're a new member, but um, this thread is 10 years old.Did you do anything with the front to keep the track the same as the rear? Spacers on the front, upper and lower arms moved out? The wider rear wound make for abundant late model rim choices, but do the fronts set in too far?
Thanks, Steve
