1 - 1 of 1 Posts
My driver's side AC duct goes through the dash behind the instrument panel, under the speedo cable (right?) and then how do I get past the headlight switch to connect to the elbow on the AC control panel? Squish the wire harness back, and squish the duct too? Seems pretty tight to me.
In other words, the black plastic elbow that connects to the back of the AC control unit on the drivers side... when installed with tabs in proper position, it almost engulfs the wires coming from the headlight switch connector. The headlight switch is indexed, so I can't just rotate it, or did they do something goofy like this at the factory?
Craig (with crooked underdash neck syndrome)
1 - 1 of 1 Posts
