All,
Here is a picture of an original 68 GT 350 carb spacer plate.
http://personal.rdu.bellsouth.net/~pdeamorg/shelby carb spacer.JPG
Here is a picture of the Boss 320 carb spacer plate.
http://personal.rdu.bellsouth.net/~pdeamorg/boss carb spacer.JPG
Both plates are the exact same thickness, the same outer dimensions/pattern, and the same PCV tube diameter. The difference is the center pattern (no impact to carb performance) and the shape of the PCV tube. If you cut the Boss carb plate PCV tube at 1.5" in length, it will have the same appearance as the original and will function the same.
