Has anyone put the disc brake set-up from a '68 Mustang to a '66 Mustang? I've heard this will work but that I will have problems with the lower ball joints and controll arms? If you know about this please help. What do I need to get this done? Can some type bushing be used on the '66 lower ball joint so that the '68 spindle will fit and I won't have to change controll arms and ball joints? Thanks for your help guys!
They will bolt right on to your 66. I think you will need the 68 outer tie rods and the ball joints are the same. If I am wrong someone will clear it up.
You will need the 68 tie rods
If 68 disc brakes bolt right in, then why is the granada swap touted as the way to go, to install disc brakes on a 66?. Is there just a lack of 68 donors for this swap?
Yes, a lot more disc brake Granadas were built. Granadas were built from '75 through '80.
For my garage shelf, I bought the Global West performance front disc set up which uses '71 spindles - the ball joint size was the same but the tie rod hole was welded up and re-machined for the '65 tie rods. I hope it works as well as they say because they weren't cheap.
I paid a lot of money to maintain stock track width! LOL
Dean T
Does a 68 swap into a 64 1/2 count? I did this because I had the spindles and wanted the smaller rotor hub. I wasn't concerned about the larger bearings. I don't recall having to change the tie rods, as the holes in the spindles are the same size as 65 drum spindles. I thought it was 70+ that had larger tie rods?? These work quite well and have been in the car for over 50K miles and it will be going to Charlotte next week.
My guess would be because the Granada parts are much cheaper than the 68 parts. The 65 and 66 parts are even more expensive.
